Old May 5th, 2005, 06:02 PM   #1 (permalink)
datboimell
Send a message via Yahoo to datboimell
MY TRANNY IS DONE>>>HELP ME
well before i start on anything i would like to get this out...............ahhhhhhhhhhhhhhhhaaaaargggg..... ..
well yea anyway im driving with a friend of mine and im cruisin......and my sterring wheel started to shake and i heard funny noises so i pulled over quick and check to make sure nothin got stuck under the car or anything....mind you i didnt turn the care off it was still on....the car made noise till i pulled over...there was nothin under the car but when i got back in and put it in gear i tryed to take off and it WENT NO WERE......it made noise and didnt move.....so my god forsaken tranny is done....i had to push this damn car almost 5 freakin miles to get home..........i need a tranny fast so can anyone help me out here.....and also my maxiam is a 95 manual......i hear that you can swap a 2k tranny as a direct bolt in...is that true........this is urgent so please respond....this all happened like an hour ago.........
datboimell is offline   Reply With Quote
Old May 5th, 2005, 07:31 PM   #2 (permalink)
brianw
Nissan Addict
Send a message via ICQ to brianw Send a message via AIM to brianw
Call a local 3rd party Nissan speciality shop, have them fix it. Shouldn't take more than a few hous.
The 95-99 and 00-01 5-speeds are not quite identical, but I forget if it is close enough to be a direct bolt-in or not. The bellhousing bolt pattern is identical but the flywheel and halfshalf dimensions I'm not quite sure of, also the flywheel crank sensor arrangement is different...
brianw is offline   Reply With Quote
Old May 8th, 2005, 09:03 AM   #3 (permalink)
datboimell
if theres that much of a difference then i dont want like a 2k tranny or anything i'll just settle for another 95 tranny if i have to....but ima look more into it.....
!!! TRANNY NUMBERS: HELP NEEDED !!! src B13 91-94 chassis 0 Aug 26th, 2004 07:13 AM
CA18DE tranny spec! boost_boy B11/B12/KN13 82-90 chassis 3 Aug 19th, 2004 03:05 PM
jdm tranny dookie GA16DE 1.6L Engine 3 Mar 16th, 2004 06:38 PM
wha da hell is wrong wit dis tranny?!?! dolomite U13 1993-1997 Altima 13 Feb 24th, 2004 09:52 PM
question about tranny and tranny support allamg B13 91-94 chassis 9 Oct 10th, 2003 02:20 PM
