my clutch is not working, when I push it to the floor it stays there and I have to pull it bakc up by hand. the master cylinder is full of fluid. I tried to bleed the system but the fluid will not come out.
sorry i have been away for a while. at first I got a little bit of foam then nothing. i can't get any pressure in the peddal. It's been slowly getting worse and then finally cut out but I can't find a leak.
I used the valve on the release cylinder. where is the second bleeder valve?
I had the same problem about a year ago. My clutch pedal would stay down, and my clutch would not disengage. The problem was the clutch slave cylinder. Once I replaced it the troubles were gone.
Eibach pro series springs, Energy suspension polyurethane bushings, CAI, Underdrive pulley, High flow cat, Intake air temp timing advance, custom port intake manifold, headers, y pipe, etc 95 SE 5speed
There is also a second bleeder screw on the metal block under your intake.... follow the flexible clutch line up from the slave cylinder and you will find it..
once you've bled the slave cylinder, you need to go up and bleed this one. should get you up and running. If not, then you have a bad master or slave cylinder.
