Old Mar 8th, 2005, 09:55 PM   #1 (permalink)
DRUNKHORSE
Dame tu cola!
DRUNKHORSE's Avatar
Exclamation my oil smells like gas !!!
i was doin my oil change and i noticed a smell. so i smell around and noticed that the smell came from the oil !!! i dont think its suppost to smell like this, im starting to think that my piston is bad or could it be just the o-ring or something else? what do u think?
Sobre un urinario decia:Un consejo de amigo,un consejo de hermano,que nunca tengas en el culo,lo que ahora tienes en la mano.
DRUNKHORSE is offline   Reply With Quote
Old Mar 8th, 2005, 10:06 PM   #2 (permalink)
Bror Jace
Nissan Addict
Bror Jace's Avatar
Question
Making lots of short trips which don't allow your engine to get fully up to temp?
Maybe your PCV valve isn't working properly (blocked).
Maybe you have a leaky fuel injector(s) which is/are loading up one or more cylinders with fuel?
--- Bror Jace
Bror Jace is offline   Reply With Quote
Old Mar 9th, 2005, 07:53 AM   #3 (permalink)
Jeff
In Ur Threadz - Deleting!
Jeff's Avatar
Send a message via AIM to Jeff Send a message via MSN to Jeff Send a message via Yahoo to Jeff
Just curious but how is your car running? Rough? Does it miss? Do you have a check engine light?
HIS: '07 Mazda CX-7 Touring...20% tint all around
HERS: '06 Mazda 3s...tint/CAI/Mazda3 pedals
GONE: '99 Maxima...i/h/e/eibachs/b&m/17s
Jeff is offline   Reply With Quote
Old Mar 9th, 2005, 07:56 AM   #4 (permalink)
Matt93SE
Will work for beer
If the engine is running properly, then don't worry about it. If you're having problems with the engine not running, then look into the causes.
My website.
Old Mar 9th, 2005, 10:06 AM   #5 (permalink)
DRUNKHORSE
Dame tu cola!
DRUNKHORSE's Avatar
im not driving the car right now. i have an electrical problem plus i think the ignition timing is off or that could be the whole cause im not sure . the car right now wont even turn on. my check engine light is on.
Best Engine Oil???? MCHNHED B14 95-99 chassis 70 May 15th, 2008 05:21 PM
hard to start, Flooding on cold start's..gas in the oil? se-r-abyss QR25 2.5L Engine 5 Jan 17th, 2008 11:43 AM
How-To: Change Oil Pressure Switch Wufaded GA16DE 1.6L Engine 0 Aug 30th, 2004 12:23 PM
Checking Engine Oil - Too High? Josh GA16DE 1.6L Engine 10 Aug 10th, 2004 05:23 PM
Oil cap question Destined E/CA-Series & GA16i Engines 9 Aug 10th, 2004 10:01 AM
