Old Nov 4th, 2003, 11:33 PM   #1 (permalink)
maxima98vspec
maxima98vspec's Avatar
Question 2000 Max Motor
WOULD A 2000 MAX MOTOR FIT RIGHT INTO A 98 MAX, AND WOULD I BE ABLE TO USE ALL MY MOD PARTS ON THAT MOTOR, IM THINKING YES CAUSE THEY ARE PREATY MUCH THE SAME BUT IM NOT SURE.
maxima98vspec is offline   Reply With Quote
Old Nov 5th, 2003, 09:08 AM   #2 (permalink)
BlueBOB
The Hair of BOOM!
BlueBOB's Avatar
Send a message via ICQ to BlueBOB Send a message via AIM to BlueBOB Send a message via MSN to BlueBOB Send a message via Yahoo to BlueBOB
it'll fit... a lot of people claim that it won't clear the hood, but one our guys in houston (HNE & d_warner <-- same person) put a 5th gen strut tower bar on his 4th gen and it barely rubs the hood and it sits higher than the motor in the 5th gen, SO, that might be an urban legend.
either way, this is what the ORG says...
2nd post
http://forums.maxima.org/showthread....4&page=2&pp=40
I'm just a big bang Baller On a Budget...
Cardomain : Dallas Nissan Enthusiasts : DNE Forums : VQPower.com - DTM
BlueBOB is offline   Reply With Quote
Old Nov 5th, 2003, 12:33 PM   #3 (permalink)
seximagtr
Another thing to consider is the harness... the harnesses for the motors are quite different....The Ecu is also different. The intake manifold is different, so things like you'r eintake won't fit.
Your exhaust parts will not fit either, the exhaust manifold won't line up...
all in all, just go get a vq30de... much simpler.
seximagtr is offline   Reply With Quote
Old Nov 5th, 2003, 03:38 PM   #4 (permalink)
maxima98vspec
well where does the 2000 motor get the 30 extra horsepower like is it because of the valves or what is the difference
Old Nov 5th, 2003, 04:24 PM   #5 (permalink)
BlueBOB
The Hair of BOOM!
BlueBOB's Avatar
4th gen max -- VQ30DE
2k, 2k1 -- VQ30DEK
the K represents the intake manifold basically... rumor has it that you can not take that intake manifold and put it on the 4th gen motor. our option for an upgraded intake manifold is the MEVI.
Old Nov 5th, 2003, 05:53 PM   #6 (permalink)
Jeff
In Ur Threadz - Deleting!
Jeff's Avatar
Send a message via AIM to Jeff Send a message via MSN to Jeff Send a message via Yahoo to Jeff
The bottom end on the VQ30DE-K is also different IIRC.
HIS: '07 Mazda CX-7 Touring...20% tint all around
HERS: '06 Mazda 3s...tint/CAI/Mazda3 pedals
GONE: '99 Maxima...i/h/e/eibachs/b&m/17s
Jeff is offline   Reply With Quote
Old Nov 6th, 2003, 10:11 AM   #7 (permalink)
seximagtr
more aggressive cams.... higher lift valving.... different intake AND exhaust manifolds.
Old Nov 10th, 2003, 09:44 AM   #8 (permalink)
HNE
Evil Moderator
HNE's Avatar
Send a message via ICQ to HNE Send a message via AIM to HNE Send a message via MSN to HNE Send a message via Yahoo to HNE
Actually Joffe, from what I hear, the cams are more docile on the DEK. The 4th gen cams are more radical. The improvement is coming from the composite variable intake and the exhaust manifolds from what I've read. I have heard that the 5th gen intake doesn't just open and close like an MEVI, but is truely variable. It will open half way about half way up the RPM range, and then the runners open more at high RPMs. As for the fitment issue, there are several problems.
If you are going to continue using your stock tranny, there may be a problem there. Your ECU will be correct for your tranny, but not the motor. If you change out the ECU, then it will be correct for the motor, but not the tranny. I think the easiest way would be to get a VQ30DEk with a 5th gen 5-speed, and do the swap from there. I'm currently venturing in another direction for my buildup, but thats a whole nother story.
d_warner@Yahoo.com
HNE is offline   Reply With Quote
