» Site Navigation
» Other Sites
Oct 28th, 2003, 01:27 PM
#1 (permalink )
Alarm disabled after battery removal
Hello
I have a 1997 Maxima SE with manual tranny; the car has 162,000 miles on it
Recently I removed the battery while replacing the starter. After replacing all parts, everything works well except for the keyless entry.
I replaced the battery in the key fob - no help.
So, I cannot open/close the doors or trunk without using the key. The red alarm light does light up when I lock the car.
Any thoughts? Something I must reset?
Thanks
Chas
Oct 28th, 2003, 01:54 PM
#2 (permalink )
The Hair of BOOM!
you probably need to re program the car to accept that key fob, go to the 4th gen section on the org and you'll find an FAQ there with instructions on how to reprogram them.
Oct 29th, 2003, 07:17 AM
#3 (permalink )
Bob
Thanks for the reply . . .
I cannot find the "4th gen section on the org" . . . hence, cannot find the FAQ of the same.
Would you please direct me to such
Thanks
Chas
Nov 5th, 2003, 12:44 PM
#5 (permalink )
Check your fuses. You may have blown your fuse for the oem anti theft system.
Nov 6th, 2003, 06:42 AM
#6 (permalink )
Bad Fob
Thanks to you both for your suggestions. Ends up the fob went bad . . . strange coincidence
$130 for a new one - no way!
Thanks again
Chas
Nov 6th, 2003, 09:23 AM
#7 (permalink )
The Hair of BOOM!
ebay is your friend!
Nov 10th, 2003, 11:04 AM
#8 (permalink )
In Ur Threadz - Deleting!
Yeah...used fobs can be had on eBay for around $20. No need in paying the stealership for a new one.
You may also find one on maxima.org...go to the for sale section.
HIS: '07 Mazda CX-7 Touring...20% tint all around
HERS: '06 Mazda 3s...tint/CAI/Mazda3 pedals
GONE: '99 Maxima...i/h/e/eibachs/b&m/17s
Nov 10th, 2003, 11:34 AM
#9 (permalink )
Still a problem
I just got my original FOB - never used.
Tried programming the car to it - not working.
Procedure and Results:
1) locked the doors and did the key thing - lamp flashes twice
2) turn key to ACC
3) push lock button - lamp flashes twice again
4) turn key to OFF position
5) try fob - no luck
Any thoughts?
Thanks
Chas
Nov 21st, 2003, 05:57 PM
#10 (permalink )
DNE Boy
might be bad relay/fuse blown, that would be your next step
Injen CAI, Warpspeed Y, DR mod, KYB GR-2 w/Maxspeed Springs
Linear Mode
