Old Jul 8th, 2003, 06:18 PM   #1 (permalink)
outsider
common maxima problems
i am in the market for a 1995-1999 maxima.
i was wondering what kind of problems should i be lookin for in these cars?
mike
the reason for my name is becasue i have only own honda products in the past
outsider is offline   Reply With Quote
Old Jul 9th, 2003, 02:56 PM   #2 (permalink)
HardlineFan
HardlineFan's Avatar
I dont know about Maxima's, but Nissan Sentra's are reliable automobiles.
HardlineFan is offline   Reply With Quote
Old Jul 10th, 2003, 09:52 AM   #3 (permalink)
stealthb14
West Coast Redneck
Send a message via AIM to stealthb14
Outsider,
There are not too many reported problems with 95-99 Maximas, because they're awesome cars. If the car was well taken care of, it will take care of you. My uncle drives a 97 Max GLE, and that sucker hauls arse, and has been a reliable ride for him.
Black 1997 Sentra GXE - Now Sporting : Hotshot CAI/15" Gunmetal Rota Subzeros/Eibach ProKit/KYB AGX's/Gen 2 Stealth Corners/more to come soon!
http://www.downshifitingischeating.com
stealthb14 is offline   Reply With Quote
Old Jul 11th, 2003, 03:35 PM   #4 (permalink)
HNE
Evil Moderator
HNE's Avatar
Send a message via ICQ to HNE Send a message via AIM to HNE Send a message via MSN to HNE Send a message via Yahoo to HNE
There are several problems that are occasionally seen in Maximas. First off, the oil pressure sending unit is prone to failure. Don't worry about it. The part is about 8-9 bucks, and its easy to get to so you can do it yourself. Second, the differential bearings in 5 speed 4th gen Maximas have been known to go bad. This usually occurs at about 80,000 + miles or so, and requires a complete rebuild of the tranny since both sets of gears have to be removed to access the differential. The way you can tell, and mine is doing it now, is if you have a leaking problem where the CV axle shafts meet the tranny. I replaced my seals, and they still leaked. IF that happens, the axles are wobbling and causing the seals to leak. You will also know if you get a whine or whirring sound when driving, espetially when downshifting. Mine doesn't do this YET, but I'm sure will start soon. The best thing to do is check the car out really good at the tranny. If you see what looks like it may be a leak, then try to get them to come down on the price. A 5 speed Maxima is very rare, but they are extremely quick. I wouldn't recomend anything less. Just be sure to check it out first. As for Automatics, there are no known tranny problems. If you are planning on doing any boosting to an auto Max, I would Highly reccomend a Valve Body upgrade, but if you simply do bolt ons, then you should be OK.
David
d_warner@Yahoo.com
HNE is offline   Reply With Quote
Old Jul 11th, 2003, 03:37 PM   #5 (permalink)
HNE
Evil Moderator
HNE's Avatar
ADDITION.
I would try to find a 97-98 Maxima. The tail lights are much easier to modify if that interests you, and the 99 model computers are OBD II and a pain to modify. If you stick to 97-98 models, you can't go wrong, but there is nothing wrong with the 95-96 models either. Both cars have the same motor, power and performance.
David
d_warner@Yahoo.com
Old Jul 12th, 2003, 07:56 PM   #6 (permalink)
outsider
thank alot david
still lookin for that max
only one i found so far was a 96 i believe with 130k miles on it
and they were still askin for 5g
Old Jul 12th, 2003, 07:58 PM   #7 (permalink)
outsider
what are the major are maintance interval in these cars?
they have a metal timing belt?
Old Jul 17th, 2003, 02:40 PM   #8 (permalink)
whiterice
Posts: n/a
97 this friday!
hi all,
i'm getting a slightly rusty 97 se this friday!
it's a 5speed. i started sfbay-corollas.dhs.org so you can imagine whatever you want about this max, but i'm just looking to give it proper TLC for the next year or so.
89k
no abs
rusted out muffler
cloth
5spd
old tires
any recommendations? prev owner seemed lax, oil changes every 4 instead of 3, but he did use syn...
-ken
Old Jun 3rd, 2007, 10:10 PM   #9 (permalink)
blackpete
Hi outsider i have owned a a32 max for 10 yrs now its done 122k never had any real problems with it.other than a new starter mtr. and belt tenshion idler pulley
both cheap and easy to replace.i would say it would have to be one of the best cars ive owned . I dont know how they rate them in the u.s. but they are problaby one of the
most under rated cars in aus. i think because people just dont know how good they are.
blackpete is offline   Reply With Quote
Old Jun 4th, 2007, 01:48 PM   #10 (permalink)
brianw
Nissan Addict
Send a message via ICQ to brianw Send a message via AIM to brianw
Did you check the sticky?
http://www.nissanforums.com/general-...-99-years.html
brianw is offline   Reply With Quote
