Old Mar 20th, 2003, 08:34 PM   #1 (permalink)
neuroguru
Posts: n/a
Max the Max Handling
HI,
Any suggestions for high-quality suspension mods for a 96 Maxima SE, for instance, anti-roll bars and shocks?
Also, are there any quality computer-chip upgrades that will enhance performance?
Thanks,
NG
Old Mar 21st, 2003, 07:43 AM   #2 (permalink)
BEJAY1
Yes for all.
RSB's from Addco, Cattman, Progress, Stillen, & others
Struts from Koni, KYB, Tokiko, and others
Chips from JWT & G-force
Autocrossing home page
BEJAY1 is offline   Reply With Quote
Old Apr 7th, 2003, 09:31 AM   #3 (permalink)
allmotormax
depending on how much you want to spend there are thousands of combinations you could go for the cheapest would be to revalve the stock macpherson struts, get stiffer springs, the most expensive would probably be an ohlins kit, check out jim wolf technology for chips etc.
17x9's, stiffer springs, revalved macpherson struts, 199,318 miles on a bone stock engine, still running strong, when it does finally break i should have all the parts i want to build a high reving allmotor terror. See you on the other side of the tree
allmotormax is offline   Reply With Quote
Old Apr 15th, 2003, 12:14 PM   #4 (permalink)
BlueBOB
The Hair of BOOM!
BlueBOB's Avatar
Send a message via ICQ to BlueBOB Send a message via AIM to BlueBOB Send a message via MSN to BlueBOB Send a message via Yahoo to BlueBOB
Wow that's a list... suspension can cost so many thousands of dollars depending on what you want out of it.
What these guys have mentioned is a great start.
Chris
I'm just a big bang Baller On a Budget...
Cardomain : Dallas Nissan Enthusiasts : DNE Forums : VQPower.com - DTM
BlueBOB is offline   Reply With Quote
Old Apr 30th, 2003, 01:57 AM   #5 (permalink)
Kanaka
I see that you already have maxspeed springs. stay with those for now and just get a good set of struts. the most popular struts right now are the kyb agx's. they run about 330 shipped on a gd on maxima.org (whenever the board gets up and running). there are better struts...i think koni may have a 4th gen application, or you can go full coilover like JIC, but they are costly. A rear sway bar helps the rear stay flat. addcoa is about 120 or so. if you want the front tighter, we do not have aftermarket front sway bars. all you can do is change the sway bar bushings to polyethelyne. it will take away the play in the bushings, but will make your ride harsher.
Kanaka is offline   Reply With Quote
