Old Feb 7th, 2008, 07:04 PM   #1 (permalink)
BoMax
97 Maxima starting problem
Problem: 97 max will not start, electrical stuff all works.
When the key is turned the starter makes no noise. Battery is new. Starter was taken to the shop and tested good.
Put the starter back in -- car started once but will not start again. I used a test light and when the key is turned there is power to the starter. I checked the relay(under dash), it clicks when the key is turned.
Try to start with the headlights on and they don't dim so I don't think the starter is pulling power.
Any ideas??
BoMax is offline   Reply With Quote
Old Feb 9th, 2008, 02:00 PM   #2 (permalink)
BoMax
Problem solved
This might help someone else so I thought I would give the solution.
After having the starter tested for the third time and being told it was good, I replaced it anyway because it was the only thing left. New starter solved the problem.
I guess the bench testers at the parts store can't show everything.
Starting problem on 97 maxima d_w_farris A32 1995-1999 Chassis 1 Mar 2nd, 2006 08:51 PM
problem with starting purduetuner149 L30 1998-2001 Altima 2 Dec 2nd, 2005 03:28 PM
Stalling problem with 92 maxima...HELP! Kristen514 J30 1989-1994 Chassis 13 Sep 14th, 2005 08:40 AM
Maxima Clutch fade problem...again ( Long) terrys A34 2004-2008 7 Sep 1st, 2005 11:16 PM
93 Maxima ECCS Relay Problem sun_123 J30 1989-1994 Chassis 0 Jan 27th, 2005 02:39 PM
