Old Jan 14th, 2008, 01:28 PM   #1 (permalink)
mccq268
oil pressure switch help
can anyone tell me where to find the oil pressure switch on a 1999 maxima
mccq268 is offline   Reply With Quote
Old Jan 19th, 2008, 12:01 AM   #2 (permalink)
blackpete
oil pressure switch is located just above rear of oil pan at bottom of motor you need 26 mm
deep socket to remove very easy to change
blackpete is offline   Reply With Quote
engine flush vs Bilstein Engine Flush vs not at all ak47m203 Off Topic 7 Feb 21st, 2008 03:06 PM
Factory Oil Pressure Sensor MagnaDyne SR20DE/DET Engines 1 May 8th, 2006 09:46 PM
oil pressure hookup on 3.3 tmeh Naturally Aspirated 0 Nov 18th, 2004 06:39 AM
Changing Oil GlowstickBoy Off Topic 5 Aug 8th, 2002 11:07 AM
Oil temp and Oil pressure gauges are done! PatScottAKA99XE GA16DE 1.6L Engine 2 May 5th, 2002 09:14 PM
