Old Jan 1st, 2008, 11:34 AM   #1 (permalink)
filipinowise
Poor Gas 99 Max
My car use to burn gas great but now it the worst ever. I have changed my spark plugs, Cleaned out my fuel system with sea foam (through vacuum line) and cleaned my k&n air filter and using lucas fuel treatment. my must be in good condition because the check engine light is not on. Any one have any suggestions??????
filipinowise is offline   Reply With Quote
Old Jan 2nd, 2008, 11:36 AM   #2 (permalink)
Akito
It could be your knocksensor. It doesn't set the CEL/SES light on. It's one of those hidden codes. Try getting codes read from your car sometime.
Akito is offline   Reply With Quote
Old Jan 3rd, 2008, 06:48 AM   #3 (permalink)
filipinowise
thanks
okay i will try that, what are the codes for the knock sensor?
Old Jan 3rd, 2008, 07:42 PM   #4 (permalink)
Akito
P0325.
Source: OBD-II Trouble Code: P0325 Knock Sensor Circuit Malfunction
I am a bit new to this site, so I am not able to provide links to within the forum.
Try the search button.
If you are a DIYer, the knock sensor is extremely hard to get to, especially if your car is a Cali Spec.
Old Jan 6th, 2008, 12:09 PM   #5 (permalink)
06murano
if you've notice that you're getting poor gas mileage only in the city, but during long highway trips it's about normal...then i would say change out your thermostat. it would affect city driving because your car never get to the ideal optimum temp with a worn thermostat, thus making it run less efficient.
06murano is offline   Reply With Quote
Recommended vs. Max Tire Pressure protege26 Frontier 14 Nov 17th, 2006 12:26 PM
Extang 'Black Max' Install + Photos! Giddy up!! AGR Frontier 11 Nov 7th, 2005 03:51 PM
Mad Max Militia in San Antonio - BEWARE Jeff Off Topic 5 Apr 18th, 2005 11:17 PM
Help! What's the ECC Light All About? SentraGirl E/CA-Series & GA16i Engines 13 May 7th, 2004 12:03 AM
Max Boost Comics NismoXR Off Topic 4 Jan 10th, 2003 12:43 AM
