Old Mar 1st, 2007, 10:56 PM   #1 (permalink)
joneill1975
Arrow Engine Dying
I have a 1999 Nissan Maxima with 150K mi on it. Today the check engine light came on and when I slow down the engine almost dies. It died once today, but most of the time it catches itself and revs back up. When sitting at a light it's idling around 550 and is very rough. I pulled the codes tonight and I'm getting 0102 (Mass Air Flow Sensor or circuit fault) and 0304 (Knock sensor or circuit fault). I had this same problem a few months ago, but was getting a Throttle Position Sensor error code along with the Knock Sensor code. I replaced the TPS and the check engine light went off until now. My question is do you think its the MAF sensor or the Knock Sensor causing the problem? I've read other problems cause the Knock sensor to come in. If its the MAF sensor do you recommend cleaning it or should it be replaced?
joneill1975 is offline   Reply With Quote
Old Mar 2nd, 2007, 07:56 AM   #2 (permalink)
Jeff
In Ur Threadz - Deleting!
Jeff's Avatar
Send a message via AIM to Jeff Send a message via MSN to Jeff Send a message via Yahoo to Jeff
MAF sensor causing the knock sensor to freak out...KS's are tempermental like that.
HIS: '07 Mazda CX-7 Touring...20% tint all around
HERS: '06 Mazda 3s...tint/CAI/Mazda3 pedals
GONE: '99 Maxima...i/h/e/eibachs/b&m/17s
Jeff is offline   Reply With Quote
Engine Knock on Mexican built GA16DE Sentras Pablo14 GA16DE 1.6L Engine 44 Jul 5th, 2006 10:16 PM
Need Advice on Engine repair meesh L30 1998-2001 Altima 7 Nov 12th, 2005 01:21 AM
Engine Cont Relay does not work sun_123 J30 1989-1994 Chassis 4 Jan 18th, 2005 07:27 PM
Engine dying past 65 MPH Estis Fatuus A32 1995-1999 Chassis 5 Jul 1st, 2004 08:35 PM
Engine Dying SkylineGTR GA16DE 1.6L Engine 1 Aug 17th, 2003 02:24 PM
