Old Feb 24th, 2007, 09:09 PM   #1 (permalink)
flmaxgle
Smile 95 GLE oil Problem
I am a newbie to the site with a 95 GLE (190,000 miles) that had an oil leak. It went pretty dry and I put 4 quarts of 5W30 in to drive home. About 15 miles later, I was dry again and added 4 more quarts. not sure where all of the oil is going. Just getting started at this and could use the help with any suggestions. Thanks from an amateur in need.
flmaxgle is offline   Reply With Quote
Old Feb 26th, 2007, 01:08 PM   #2 (permalink)
brianw
Nissan Addict
Send a message via ICQ to brianw Send a message via AIM to brianw
Eeek. If you're leaking that much oil, just get down under the car and look for the massive oil slick!
Then get some towels, wipe it down, and see where oil is seeping out of. Sounds like you've got something pretty major under there.
brianw is offline   Reply With Quote
Old Feb 27th, 2007, 05:57 AM   #3 (permalink)
flmaxgle
That just the thing, it isn't leaking that much. I am now reading full on the oil stick and the slow drip is there. I ran it for a while in the driveway and it now just overheats. The temperature gauge goes from the middle to hot fast. It smells like oil burning and I have a slight smoke coming out of the exhaust. Could it just be antifreeze or a thermostat problem??? Any hints?
Old Feb 27th, 2007, 01:31 PM   #4 (permalink)
brianw
Nissan Addict
Have a shop look at it. Sounds like you're not sure what's happening AND you have what may be *several* problems... do the fans come on when it gets hot?
If the oil's not going on the ground are you having issues getting a proper reading off the dipstick? Is the smoke white, blue,or...?
Adding an Oil Cooler, but why? chimmike Members featured Project cars 6 Mar 18th, 2007 01:05 PM
Changing Oil types ace B13 91-94 chassis 18 May 6th, 2006 10:10 PM
Limited time showing, come one come all!! Marvin Off Topic 43 Jan 14th, 2005 07:35 PM
Oil pressure flickering after VC repair yakhunter U13 1993-1997 Altima 6 Feb 14th, 2004 11:08 PM
change your own oil sethwas B14 95-99 chassis 82 Dec 28th, 2003 06:12 PM
