What's up forum? I have a '97 Max SE Auto with 138K miles. I've had the following done since I purchased the car with 108K miles:
NGK Plugs, Air Filter, Oil Change (of course), Transmission Oil Change, PCV Valve, Cleaned Throttle Body, EGR Canister replaced, changed MAF sensor with used part, One Ignition Coil replaced, Fuel Injection Cleaning & new TPS with adjustment.
My car continues to be sluggish during initial acceleration (when I push the accelerator, the car delays before going). There's also lack of power when accelerating while riding. It seems like I have to almost floor the pedal to get a decent boost and even that seems like it's being restricted (VERY FRUSTRATING)!!!! The car was in very good shape when I purchased it but there's something holding my baby back!!!
Any professional advice would be appreciated. I was thinking my MAX may need the following to fix the problem and also as just 138K general maintenance:
1) New Fuel Filter
2) Transmission Oil Flush (not just a change)
3) Coolant Flush (or change...please advise)
4) Fuel Injector(s)???
5) Ignition Coil(s)???
6) Ignition Timing Adjustment???
I really do believe I have a good car and want to experience its true performance, but I need that antibiotic....HELP?
