Old Feb 8th, 2007, 11:58 AM   #1 (permalink)
Rubheat83
Need Help, Oil measurement wrong.
I have a 97 maxima, and im having some trouble with the oil measurement, the car has been unused for a while, but it still starts up. when i pull the oil stick out with the car off, it measures lower than what it has, and when i try to measure it with the car on and warm, the oil measures too high, also there is some oil leak under the car and it looks like its coming from the oil pan, maybe it has a messed up gasket, im not sure if this may be causing the oil to measure wrong, can anyone tell me what im dealing with here, thx.
Rubheat83 is offline   Reply With Quote
Old Feb 8th, 2007, 01:18 PM   #2 (permalink)
Jeff
In Ur Threadz - Deleting!
Jeff's Avatar
Send a message via AIM to Jeff Send a message via MSN to Jeff Send a message via Yahoo to Jeff
Never measure with the car on/running...the oil is cycling through the engine so you will never get an accurate measurement.
How bad is the oil leak?...is it on the ground or do you visually see it on the pan itself?
HIS: '07 Mazda CX-7 Touring...20% tint all around
HERS: '06 Mazda 3s...tint/CAI/Mazda3 pedals
GONE: '99 Maxima...i/h/e/eibachs/b&m/17s
Jeff is offline   Reply With Quote
Old Feb 8th, 2007, 02:02 PM   #3 (permalink)
brianw
Nissan Addict
Send a message via ICQ to brianw Send a message via AIM to brianw
Remove dipstick.
Wipe dipstick.
Reinsert dipstick fully, then immediately withdraw and examine oil level on dipstick: this is the best way to get an accurate measure on the VQ30DE.
brianw is offline   Reply With Quote
Old Feb 10th, 2007, 03:40 AM   #4 (permalink)
Rubheat83
part of the oil is on the ground, but if you look under the car there is no oil dripping. When i check the oil with the car off the oil measures really low and when i turn the car on, the oil measures too high, sort of like if it was goin crazy in there.
Old Feb 10th, 2007, 03:43 AM   #5 (permalink)
Rubheat83
Originally Posted by brianw
Remove dipstick.
Wipe dipstick.
i do just like you mentioned, but even so the oil measures completely wrong, on one side its all over the dipstick from the low end to a little higher then the max level, and on the other side it measures low.
Old Feb 12th, 2007, 06:38 PM   #6 (permalink)
brianw
Nissan Addict
Is the engine cold? If it's warm, you're never going to get an accurate reading.
Also you should be reading just from the low point on the marked side.
Old Feb 13th, 2007, 01:43 AM   #7 (permalink)
Rubheat83
the oil is just all over the stick, i would say like from half way down. could that have something to do with the oil pan gasket not holding the oil inside?
Old Feb 13th, 2007, 01:21 PM   #8 (permalink)
brianw
Nissan Addict
Probaby not, since the gasket is very low...
I would get the oil leak fixed and see what the deal is.
Old Feb 20th, 2007, 04:58 AM   #9 (permalink)
niznos
niznos's Avatar
Send a message via Yahoo to niznos
I have found that it is hard to get a good read on the dipstick immediately after engine shut-down. Oil was just splashed up onto the dipstick tube and it will read all over the place. If you wait a couple minutes after shut-down on a warm engine, you will get good readings; and sometimes it take a couple of dips. Make sure you are parked on level ground too.
niznos is offline   Reply With Quote
engine flush vs Bilstein Engine Flush vs not at all ak47m203 Off Topic 7 Feb 21st, 2008 03:06 PM
Changing Oil types ace B13 91-94 chassis 18 May 6th, 2006 10:10 PM
Limited time showing, come one come all!! Marvin Off Topic 43 Jan 14th, 2005 07:35 PM
Oil pressure flickering after VC repair yakhunter U13 1993-1997 Altima 6 Feb 14th, 2004 11:08 PM
change your own oil sethwas B14 95-99 chassis 82 Dec 28th, 2003 06:12 PM
