ignition immobilizer/security systems problems
Hi, I own a 99 nissan maxima and I'm experiencing some problems with my ignition immobilizer. I stopped to get some gas on my way home, turned engine off and havent gotten it started yet. Initially, the vehicle started and died within the first 5 seconds. Then the car started again and died within first 2 seconds. After that, the engine turns over, but is unable to run. All fuses are good, both inside the car and engine compartment, and relays look fine. When I turn the ignition on, I can hear the fuel pump power up (suggesting the motor is getting fuel) but I noticed the dash mounted security light stops blinking and stays illuminated and it's only AFTER I turn the key to enable ignition. The owners manual suggests that this is caused by a malfunction with the ignition immobilizer and recommends resetting the system. Tried that, didn't work. Also scanned ECU and got my usual code, rear 02 sensor, and a new one: EGR, then reset ECU. But this wouldn't disable ignition. Also went home and picked up spare key thinking that the transister in the orginal might have gone bad but that didn't work either. SO anyway, I'm at a loss. If anyone else has experienced this or something similar, it would be of great help if you could give some suggestions. Thanks
