Old Jan 20th, 2007, 02:56 AM   #1 (permalink)
maxforce
ignition immobilizer/security systems problems
Hi, I own a 99 nissan maxima and I'm experiencing some problems with my ignition immobilizer. I stopped to get some gas on my way home, turned engine off and havent gotten it started yet. Initially, the vehicle started and died within the first 5 seconds. Then the car started again and died within first 2 seconds. After that, the engine turns over, but is unable to run. All fuses are good, both inside the car and engine compartment, and relays look fine. When I turn the ignition on, I can hear the fuel pump power up (suggesting the motor is getting fuel) but I noticed the dash mounted security light stops blinking and stays illuminated and it's only AFTER I turn the key to enable ignition. The owners manual suggests that this is caused by a malfunction with the ignition immobilizer and recommends resetting the system. Tried that, didn't work. Also scanned ECU and got my usual code, rear 02 sensor, and a new one: EGR, then reset ECU. But this wouldn't disable ignition. Also went home and picked up spare key thinking that the transister in the orginal might have gone bad but that didn't work either. SO anyway, I'm at a loss. If anyone else has experienced this or something similar, it would be of great help if you could give some suggestions. Thanks
maxforce is offline   Reply With Quote
Old Jan 20th, 2007, 12:51 PM   #2 (permalink)
mech361
Does the security light come on and stay on with the spare key as well?
mech361 is offline   Reply With Quote
Old Jan 20th, 2007, 07:36 PM   #3 (permalink)
maxforce
yes. Have you ever experienced or heard of this happening before?
Old Jan 24th, 2007, 06:10 PM   #4 (permalink)
mech361
Sounds like the keys need to be coded by the dealer. How they lost their code is a mystery, but I've seen it happen before. The steady red security light means the NATS system does not recognize the key.Chances are there is a difference of key error code stored in the NATS system as well. Having the code cleared and the key recoded by the dealer is the only way I know of to repair this. Someone else may know another way.
Old Jan 25th, 2007, 12:39 PM   #5 (permalink)
fgoodyear
I have a '99 MAxima also. Mine did it. I had it towed to the dealer and ALL the keys reprogrammed. Do you have a remot start installed? They said mine might be interferring with the key code although it was installed when new. In the owners manual the is a section that tells how to override it to get it started to take it to the dealer. I, however, didn't find that section until after I got it to the dealer.
fgoodyear is offline   Reply With Quote
Old Feb 22nd, 2007, 11:51 AM   #6 (permalink)
nestorb
We just bought a 2001 Maxima last week...it only came with one key and no key fob...the other day I decided to call Nissan and ask if a fob is available for it...they want $157.00 for the fob and 45.00 to program it...at that point I forgot to ask about a 2nd key...is there a cheaper alternative to buying the fob from Nissan and are programming instructions available somewhere on the web?
Regards,
Barry Nestor
nestorb is offline   Reply With Quote
Old Feb 24th, 2007, 02:51 AM   #7 (permalink)
brianw
Nissan Addict
Send a message via ICQ to brianw Send a message via AIM to brianw
Buy keys from a discount Nissan parts dealer. Probably still $90 or so. Then have your local dealer code them.
brianw is offline   Reply With Quote
Old Feb 24th, 2007, 08:39 AM   #8 (permalink)
red613
try looking on ebay , i have boought 2 used fobs in the past for about $25.00 each ,
there is reprogramming info on the web , basically you get in the car put key in and out 7 times in 10 seconds they turn igintion to on and press the big button and it reprogams itself.
red613 is offline   Reply With Quote
Key Won't Turn In Ignition Rama B14 95-99 chassis 15 Mar 10th, 2006 12:52 AM
96 Maxima 3.0 Ignition Problems DBlack A32 1995-1999 Chassis 11 Feb 2nd, 2005 07:43 PM
99 Maxima ... Problems With Primary Ignition Coils Lazarus A32 1995-1999 Chassis 29 Dec 15th, 2004 05:44 PM
Ignition Systems Question MSD, etc EuroStylz B11/B12/KN13 82-90 chassis 1 Jan 3rd, 2003 03:18 PM
Ignition Systems SilverSentra99 GA16DE 1.6L Engine 22 Jan 3rd, 2003 03:06 PM
