Links
Go Back   NissanForums.com > Nissan Models > Maxima > A32 1995-1999 Chassis
Old Sep 2nd, 2006, 10:22 PM   #1 (permalink)
Johnny P
Brake and Battery Dash Lights Stay On After Alt. Replacement
Please help. I can't figure out why my Brake and Battery dash lights won't turn off after starting my 98 Nissan Maxima SE.
I've checked the following:
1) Engine Off - Battery voltage 12.8v
2) Engine On - Voltage 15.1 max dropping to 14.7 (lights on, A/C on, fans on)
3) Negative Battery Terminal to Alt. Case = .04v
4) Positive Battery Terminal to Alt. Output = .1v
I'm at a loss... All the above readings are within the ranges specified in the documentation of the reman'ed Nissan alternator I installed.
I will say this... The first time I started the engine after the alt. replacement, the brake and battery dash lights did NOT stay on. However, they have each time after that. Hmmm..
Thanks in advance for any advice.
Johnny P is offline   Reply With Quote
Old Apr 7th, 2008, 06:20 PM   #2 (permalink)
Chest_Rockwell
Unhappy Same/Similar issue
My car has the same issue but the temperature gauge moves back and forth rapidly as well.
Chest_Rockwell is offline   Reply With Quote
Old Apr 8th, 2008, 10:33 PM   #3 (permalink)
Johnny P
Problem was a blown fuse
I found that problem later that day. It was a blown fuse under the hood -- not in the dash. Can't remember which one.
I think that happens a lot with alternator shorts or replacements...
Old Apr 20th, 2008, 05:52 PM   #4 (permalink)
Chest_Rockwell
I checked all of the fuses next to the batery and they appeaed fine.
Did it happen to be elsewhere?
Thanks,
Old Apr 20th, 2008, 08:28 PM   #5 (permalink)
Johnny P
Did you check the fuses with a multi-meter? Sometimes the visual inspection isn't perfect...
If I recall correctly, it was a 7 or 15 amp fuse.
01 Maxima dash light shows brake & battery pcumming A33 2000-2003 Chassis 3 Jul 4th, 2006 01:18 PM
Brake and Battery lights on, but not regularly omvvln L30 1998-2001 Altima 1 Jun 16th, 2006 06:46 AM
brake airbag and battery lights jiggajc L30 1998-2001 Altima 5 Jan 23rd, 2005 10:25 AM
Battery and Brake dash indicators on Greg200SE-R B14 95-99 chassis 4 Dec 29th, 2003 02:11 AM
Battery and brake warning lights CrunchyCookie B14 95-99 chassis 7 Nov 30th, 2002 07:54 PM
