Power Steering Noise - Nissan Forum
post #1 of 4 Old May 28th, 2006, 09:41 PM Thread Starter
I have been having a winding/whirring/buzzing noise coming from the engine of my 98 maxima. The Local Firestone shop couldn't find the problem, then thought it was a pulley, and replaced the pulley, but that didn't fix it.
I took it to a dealer and they said it was the power steering pump, but wanted $895 to replace it. The Firestone place said they could replace it for $395, so I let them do it.
The problem is that that didn't fix the noise. The Firestone guy said that a new power steering pump will make noise for a few hundred miles, until the "seals get broken-in", or something like that. However, it has been a week, and the noise is getting worse.
So, my questions are: is the Firestone guy full of it when he says it is normal for the new pump to make noise? & what could the noise be? - Could a bad install of the pump (leaving air in the line, etc.) cause the noise?
TokenWasp is offline
post #2 of 4 Old May 28th, 2006, 10:50 PM
Will work for beer
the Firestone guy is an idiot.
usualyl what happens with these systems is the hoses will begin to leak and will cause air bubbles in the fluid.
If there is air in the line and no leaks, it should all bleed out after a few turns lock-to-lock while the engine is off.
If the noise is still there, then there's still air in the system. most likely, it's coming in from the low pressure return line if you've replaced the pump and it still makes noise.
Also make sure you're/they're using the correct fluid. Nissan uses automatic transmission fluid in their power steering systems, NOT power steering fluid as you would think. if it's been filled with the wrong fluid, then it could cause the brand new pump to fail within miles and take down the rest of the system with it.
Matt93SE is offline
post #3 of 4 Old Jun 7th, 2006, 09:49 PM
...Are you sure it's the power steering pump making the noise? If you take the belt off will it go away?
Hydrolock is offline
post #4 of 4 Old Jun 8th, 2006, 09:56 AM Thread Starter
Actually, it wasn't - here's the update:;
I took it back to the Firestone place because the noise never went away, and asked them to try again to find the source of the noise. They did the belt-test, isolating one thing at a time until they determined it was the A/C compressor. They said it would cost about $850 to replace it. I got a couple of other quotes that ranged from $1,033 to $1,200.
I had paid $95 for an incorrect diagnosis from the dealer, and then spent an additional $400 to replace a power steering pump (that did not need replacement). An now I was faced with at least $850 more.
So, I went back to the dealer and explained the situation to the service manager. I was prepared to ask for the A/C compressor to be replaced, with a credit for the approximately $500 I had spent on, or as a result of, their incorrect diagnosis. He said that they should have done the belt test originally (their original diagnosis was simply driving and listening), as that was the only way to correctly diagnose the problem, with and would look at it again and let me know.
After they looked at it, he called and said that it was in fact the A/C compressor, and that they would replace it for me.......at no charge. When I explained I never expected for them to do it at no charge, he said that he consideres his Techs to be the best and was therefore extremely embarassed that this had happened.
Needless to say, I was amazed, but very thankful.
  Nissan Forum > Maxima > A32 1995-1999 Chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Leaking Power Steering Fluid gigascott J30 1989-1994 Chassis 9 May 26th, 2006 08:54 PM
00 Frontier power steering out-pump, belt or hose? dlj189 Frontier 11 May 24th, 2006 06:40 PM
Disabling Power Steering on '91 240SX snunes S13 240SX 1989-1994 4 May 15th, 2005 05:50 PM
Flushing power steering. Tavel B13 91-94 chassis 23 Mar 27th, 2005 03:33 AM
Power Steering 240luvr S13 240SX 1989-1994 9 Mar 9th, 2005 04:56 PM
You may post new threads
You may post replies
BB code is On
