Here is the problem. Hoping someone can help.
2 weeks ago my son's pulsar overheated quite badly steam coming out of overflow tank.
I filled everything back up and engine was still running OK for 235k engine.
Problem was now it was using coolant and not leaks could be found.
Then the oil turned into a cappuccino mess.
So I pulled the engine down sent the head away for pressure / vacuum test and decking.
Changed pistons, rings, big-ends, all gaskets.
Head came back tested all OK.
So all back together and all should be go, Sounds reasonable hey.
No.....
Engine runs fine, doesn't overheat, but still using coolant and still getting into oil.
Anyone have any ideas or come across this before.
I am loosing my mind over this.:balls:
Thanks Chris
No.....
Thanks Chris
